My ax has got problems, its started puffing blue smoke out of the exhaust under acceleration, gets worse under load, but seems to be running ok and starts up fine, its only done 61k miles aswell
Am i right in assuming the rings are worn? havent had chance to do a compression test yet, anything else it could be?
Ax 1.5 diesel blue smoke problem
madasafish
ScottFromNZ
AndersDK
vanny
Its common on this engine!
Unless it's gone all of a sudden then it's a quick fix, you'll also found its very low on power and the ecconomy is likely to be lacking!
im not sure about exactly how it happens but its apparently the tappets/valve clearances, my mums had its valve clearances reset and the difference was amazing, it positively flew afterwards! Didnt cost much mostly labour i think!
BUT try the obvious things first as listed (air filter, oil filter etc)
