Am towards the latter end of removing the head, first time have done one. I have looked at BOL and it states to remove the front plate bolts, where the injection pump mounting bracket is. Is this completely necessary or a typical BOL overkill? It was getting dark so I stopped for the eve as I couldn't really see the relevant nuts and bolts.
I have removed all pipework, manifolds, fuel filter housing, o/s mount, timing belt and casing, injector fuel pipes, so pretty far in and hope not too far off, just the last hurdle.
I have removed all tyhe head bolts as well, just have this business with the front plate left.
Any tips for the final push appreciated.
Xantia 1.9td Cylinder head removal
Dave Bamber
