Oil on the garage floor??
Yes, place your time and money saving tips here.Nothing illegal or dangerous please!Motoring related only please.
citroenzx
Post by citroenzx »
Use a solution of washing powder and watch that concrete sparkle![:D]
Stuart McB
Post by Stuart McB »
Don't put it on the drive though as it takes up the tarmac.
citroenzx
Post by citroenzx »
i've also found that brake cleaner also works!
dan.2cv
Post by dan.2cv »
When I was a valeter I decanted some wheel acid into a cup the handle had fallen off of to make it easier to apply by brush. Within 3 days it had eaten through the cup and turned the surrounding concrete green. The ball bearings in spray bottles used to last just one go. It was, unsurprisingly, a rather effective alloy wheel cleaner though.
ActivaV6uk
Post by ActivaV6uk »
The real answere to this is absorbent cat litter, if you put it on oil its soaks it all up, even after its seept into the concreat sometimes!
Andy
howiedean
Post by howiedean »
Tesc*'s cat litter is pretty good. It is the closest stuff to that I have used at work to mop up spilt fluids from Tornado F3's.
__CA__
Post by __CA__ »
Or cement.
