Jacking a sunken Citroen
When the car is too low to get a jack underneath it and theres no way of lifting it, heres a way of getting it up.
Get a small bottle jack and one of those wheel wrenches with the long double ended sockets. Put the socket onto the wheel nut and the long socket has enough length out by the end of the wheel to use the bottle jack on it. When high enough you can get the trolley jack underneath no problem. Works well on the long headed wheel studs on the Xantia anyway [:)]!
Brian
97 Xantia TD
93 Xantia SX TD ( headless, gearboxless .......)!
Brian
97 Xantia TD
- Locked user account
- My Cars: C5 X7 2.7 hdi
Past cars
Activa, silver MK1 (221bhp stock) stripped out with twin sparcos Evo seats. 95
Activa, light met red MK1 98
Activa, dark met red MK1 98
Activa, dark met blue MK1 (202bhp stock) 96
Xantia exclusive V6 auto 3l 98
Xantia 2l 8v auto
BX 4x4 GTi dark met silver
BX 4x4 GTi white
BX GTi 16v white fibre bumpers
BX GTi 16v black fibre bumpers
BX GTi 16v hurricane (doa)
BX DTR estate
People need to be carfull with this, scissor jacks should not be used, I've had 2 very close calls with them and as some one pointed out in another post then are not meant to be used from the "almost" close position. I have to say I like the looks of the bag jacks its definatly a way to get the car lifted safly to begin with then use a trolly jack.
Vanny did you buy that lift?
Andy
Andy
In my workshop I have numerous blocks of wood of varying sizes, in the event of having a flat citroen I assemble wooden blocks into a low ramp and drive/roll the car up it until I have enough space to get a trolley jack in, once the wooden blocks reach the end of their useful life they burn very well in my multifuel heating system.
Stewart
Stewart
Scissor jacks work fine in an emergency, and thats usually what a flat citroen is- you only need to lift the car just enough to get a trolley jack under- I have done this a few times as flat hydragas cars have the same problem!!
They may not be meant for this use but they will work-I have an ex Honda one which seems better engineered than most cheapo scissors.
Tow bar? that my method anyways! (and i mean on my fancy new compact towbar, not the old scaffold one!
Andy no i didnt ge tthe lift, it was stolen with 6 seconds left at a mear £86! For those that don't know what im on about, there was a 3tonne 4 post lift on ebay about an hours drive from mine and i kinda had a place to put it up and use it! £86, i'm kinda gutted!
I do like the wooden ramp idea though!
Would it be possible to mount hydraulic jacks into the floor of a garage, similar to rally cars that self jack, but from the floor up?
Past cars
Xantia 2l 8v auto
BX 4x4 GTi white
BX DTR estate
As said above, I've used the towbar ( lowest part ) before to raise the rear - chocking the jacking point as I go along on both sides with wood / brick to make it a litle more safe.
Then, when there is enough room, chock the towbar, remove the chocks from one side, and lower.
These bags are ok as long as you can start the car !
