Dash
ezee_duzit
Dash
Unread post by ezee_duzit »
I've lost a dash light behind the fan Speed/hot&Cold/ dials how do I get behind the dash to sort the problem?
I have a 1999 306.
Cheers
EZ
bad driver
Unread post by bad driver »
remove steering column shroud, then the trim in front of the clocks and then the clocks come out. Very simple to do.
bad driver
oops, sorry, I missed the part about being fan switches, the lower section of the console prises off, then there is 2 screws behind it and 2 8mm nuts either side of the stereo which will give you access to the section your requiring. If its a pug stereo then theres 2 little slits along the bottom edge where you can insert 2 fine screwdrivers to release the fasteners for removing the stereo.
My tip, put a piece of cotton on the 8mm spanner when removing the nuts and tie it to gearknob or something, if you drop the spanner inside its gone forever otherwise.
robins1uk
Unread post by robins1uk »
The idea about the spanner is a good one, i am still trying to find a spanner i lost...
