Hints and Tips Required
littleredrooster
Unread post by littleredrooster »
I am just about to buy a 2001 Xantia HDi 110 after years of good service from my 405 T-D (see 'For Sale' forum).
Anyone got any tips as to what I should look for before handing over the cash? I've checked the obvious like history (fleet car, so religious servicing), no accidents, panel-fit etc.
Any help appreciated.
406 V6
Unread post by 406 V6 »
The usual hydraulic thingys:
Sit on each corner and see if it sinks some 4 inches or so. If it's hard the spheres are shot. It should also rise to it's normal height with your weight during the test.
Listen to the click from the PR. Less tahn 20s, needs a new acc sphere.
I think it's about all, at least some o f the important bits...
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Take a peek in the LHM reservoir. If it's fluro green, the system has probably been well looked after. If it's dirty brown, it's been neglected. Same applies to the cooling system.
littleredrooster
Thanks, chaps. Should be collecting it this Thursday if all goes well.
MikeO
Unread post by MikeO »
Hi LRR
Mike[:D]
soupy_sam
Unread post by soupy_sam »
When doing the weight test should the engine be running?
pete_wood_uk
Unread post by pete_wood_uk »
Yes, if it's a hydractive example, even for the bounce test the engine should be running, otherwise it's likely to go into "hard" mode on you in mid-test, and you'll not hear it do so if you're out in trhe open. Also, you'll want to see if the car jacks itself up again after being sat on, and you need the engine running for that with any sort of Xantia...
Pete
littleredrooster
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MikeO</i>
Hi LRR
Mike[:D]
Hullo - wot you doing here?? [:)]
Are you still domiciled in Scotia?
citroenzx
Unread post by citroenzx »
Probably worth going through some of the things that the mechanics do on an MOT test, also make sure the car isn't started before you go to look at it.
jeremy
Unread post by jeremy »
Beware if the mechanicals are too clean - how well do you do a head gasket if you are selling a car?
jeremy
MikeO
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by littleredrooster</i>
Hi LRR
Mike[:D]
Got a high mileage Xantia - this is an essential site! Living down in Norfolk - back into my own house in about 4 weeks...
Mike
