Perhaps someone could help diagnose a couple of problems with a turbo diesel Xantia N reg please?
When stationary or moving, but worse I think shortly after first starting the car and going somewhere, turning the steering wheel produces a kind of grumbling, grinding, rumbling type noise which you can even feel in your feet in the passenger side but seems to be felt mainly on the steering wheel. Like a very rapid thumping oscillation.
Also noticed the brake pedal juddering visibly when it is just pushed in a bit whilst car is stationary, accompanied by a juddering noise to match the visible movement.
Any ideas what this could all be?
Other thing is 5th gear goes in when driving but grinds and pops straight back out, just like you'd expect if you'd only half-pushed a gear in - it grinds, rumbles and pushes back out. No matter how hard you ram it in, it pops straight back out, so no 5th gear in the car at the moment. Sticking it into reverse makes it crunch and grind as well, as though the clutch hasn't disengaged properly. All other gears are fine and quiet.
Now it's over to you.
