206 Oil filter Changing
JohnWB
I have a 2001 206 1.4 which seems to have a strange sort of oil filter. It is not the usual metal screw on sort, but it seems to be a paper cartridge type which hides under a large black plastic cover. Has anyone changed this type of filter and if so could you let me how to do it as I don't want to get oil every where & not fit the new one correctly
tonespeed1999
- x 1056
JohnWB
fastandfurryous
- x 4
.. a local peugeot garage would tell you that black is white if it meant that they made some money out of you by charging you through the nose for routine maintainence. My local pug dealer gets incredibly snotty when I tell him that I can fit things myself, and that I do actually know how to use a multi-meter thankyouverymuch! Mind you, I don't think it helped when after asking for a wiring diagram for the bitron sensor/system for the air con on my 405, he said "No, you can't have that, it's very complicated". To which my reply was "To you, maybe"
