Rear Wiper Arm
ezee_duzit
Rear Wiper Arm
Unread post by ezee_duzit »
Whilst giving the car a wash at the weekend, I decided to change the wiper blade on the back around. Trying not to force it to hard as the wiper arm is only plastic but the blasted thing wouldn't come off. I got a bit frustrated and did break the plastic wiper arm? Does anyone know where I can get hold of one of these from, Peuegot dealer are expensive and no other places seem to have them.
Also where it's bolted on to the rear tailgate/boot I can remove the nut under the plastic cover but the are has corroded around the thread and I can't seem to remove it with anything. Any ideas?
Cheers
EZ
fastandfurryous
x 4
presuming this is a 306. The arm will be main dealer, or a scrappie. To remove the nut use bucketloads of wd40 applied at regular intervals, and when it does finally move, work the corrosion out by alternatly undoing it and then doing it back up again, whilst continuing to apply more wd40. It makes a mess, but at least it shoudn't shear off.
You may be able to fit the earier metal arm if that's all you can find, although these have the washer nozzle built in to the base of the arm, and may be a different fittment. I'm not sure, but a quick look at one in a scrappie will tell.
