volcane lowering springs
citroenzx
Unread post by citroenzx »
Can the volcane lowering springs be put onto a ZX 1.4i? GSF sell the set for £35.
cornishbx16v
Unread post by cornishbx16v »
Arnt the shocks them selves different???? i know they are for 205/309's as i am selling some gti lowering springs at the mo, and afaik they only fot the gti/td's due to the shocker????
citroenzx
I don't know, thats why i'm asking.
Jon
Unread post by Jon »
No, Volcane ones will not fit the 1.4.
rossnunn
Unread post by rossnunn »
are you sure?? I know the damper on the volcane is uprated but is it physically different??
Jon
For start, the Volcane damper is physically shorter. The damper rate is also different. With regards to actual "fitability" I can't compare them as I'm not in work. A quick look at Volcane springs on pr-net shows different springs for petrol Volcane, then TD Volcane are different again. Part numbers completely different from 1.4 petrols.
Ross, didn't you lower a 1.4? What did you use?
VisaGTi16v
Unread post by VisaGTi16v »
I would have thought that early 1.9 ally volcane petrols had different springs to the later 2 litre and diesel iron ones as well due to less weight.
citroenzx
Jon, do you know the "fitability" of the springs yet?
