hi,
i drive a ZX 1.4i elation, recently when i drive off in the morning or when the car's been left for a while i get really serious flat spots and it makes it feel like accelerating through a big puddle!!!
it only happens for a few seconds, but i'm sure you can appreciate that when trying to nip out of a junction lack of acceleration can be serious!!
once the problem has cleared the rest of the journey is fine!
i've serviced the car, so fuel filter, air filter sparkplugs, and the ignition leads have been changed, ruleing out these being the problem. i've also checked out the injector which is spotless.
the problem has only started during the winter, meaning cold and damp. also stangely enough the problem doesn't always happen, but i cant spot any obvious differences between when it does and doesn't do it
cheers
zx flat inital acceleration
Stuart McB
mpr1956
I wonder if there could be some icing up of the intake manifold due to the cold weather ? do cars still suffer from this ? This could account for the feeling of driving through a large puddle when cold. (You would have to have been driving for a fair few years to recognise these symptoms... it would feel as if the choke had been left pulled out)
FDV
citroenzx
cold start valve looks a good place to start, not sure about the iced up manifold as it hasen't really been that cold all winter, but the symptoms are correct.
the plugs are bosch super 4's with their silicone leads, so that shouldn't be a problem.
does anyone know if the coil packs break down on the zx's?
cheers for the suggestions much better than the other citroen forums, Keep them coming.
Twiss
Had a problem like this on my girlfriends Saxo (1.1i) serviced it using champion EON 1 sparks, cooper filters and primed the fuel filter with Forte injector cleaner(shoved reast of bottle in the fuel tank and itlain tuned it and sorted the prob out.
I agree with looking at the cold start valve, Have u found that it is drinking more fuel then normal?
citroenzx
Stuart McB
What kind of coil pack? Is it one of those all in one jobs with no moving parts to be seen. Just the leads coming out to the plugs. If so, yes they to can break down after about 50K or 4 to 5 years. Had one changed on first Xsara for that reason. It caused intermittent starting and very poor running. As for the super 4 plugs they should be OK.
citroenzx
arry_b
citroenzx
rossnunn
I had this on the elation, very nearly smashed it up, nipping out of junctions & the thing dies. Changed the plugs (checked gaps) & filters, had the ECU read, found nothing, put it down to iceing until it did it after the thing had been in the sun all day, in the end the thing blew its head gaskit so never did find the cause.
Seems quite common tho, talking to people, all have elations, all with the SPI in it. Strange
rossnunn
