Xantia ABS ECU
kafkaian
Xantia ABS ECU
Unread post by kafkaian »
Does anyone have a circuit diagram (or can advise)for the ABS ECU to the ABS sensors? I am trying to measure the resistances of each sensor by checking at the ECU end, but can't tell where each connector blade is going. I'm doing this before taking the car to Citroen for a diagnostic[B)]
Cheers in advance fellas (and any ladies)
Richard Gallagher
Unread post by Richard Gallagher »
Do a search on 'Xantia ABS resistance' and you will find loads of info.
kafkaian
Cheers fella
