Hi everyone,
looking for abit of advice here. Im going to change my car and i am hoping to get a renault laguna (petrol) for around £3000 year 2000 if possible.
Im unsure about engine size. Either 1.6 or 1.8.
how does the laguna perform on a 1.6 engine size, or do i need the 1.8 engine for that size of car.
Also could someone please advise on what Insurance group that this car falls into
all the best
tom
Advice on Renault laguna purchase
tonespeed1999
welshy
tonespeed1999
welshy
my main concern is for the engine size.
I currently have a 1.9td citoen advantage, and its got that extra littlebit of power when you need it.
Is the laguna a car that really needs a 1.8 engine for good motorway driving ?
because i was concerned that the 1.6 would be sluggish for a car that size
cheers
cheers
bwellard
roaddigger58
Bwellard laguna must be an early 8 valve model if it is 94 bhp.Mine is a 1999 model 1800 16 valve and has 123 bhp.Ok,it needs to be revved a bit,but it will rev to 7000rpm before the limiter comes in,and i find it surprisingly quick.The 2 litre 16 valve has more torque for the hills,wereas the 18 has to drop a gear to keep the revs up.avoid the 16.i tried one and found it ran out of puff on the hills but was ok on the motorway.hope this helps.
roaddigger58
Bwellards laguna must be an early 8 valve model if it is 94 bhp.Mine is a 1999 model 1800 16 valve and has 123 bhp.Ok,it needs to be revved a bit,but it will rev to 7000rpm before the limiter comes in,and i find it surprisingly quick.The 2 litre 16 valve has more torque for the hills,wereas the 18 has to drop a gear to keep the revs up.avoid the 16.i tried one and found it ran out of puff on the hills but was ok on the motorway.hope this helps.
