xantia radio - am/mw interferance
shaunthesheep
Unread post by shaunthesheep »
hi all,
i've got a problem, when ever i tune my sony cd player onto medium wave or long wave, i seem to get interference only with the engine running. was was informed that it might be caused by unsupressed ht leads
i've changed the ht leads to the ones from andyspares (told were supressed to cure interference), but to no ava.......
any ideas
dom
kathbert
Unread post by kathbert »
I had the same problem on my xantia fitted radio, it turned out to be a bad connection between the aerial plug earthing and the radio. A good cleaning with emery paper round the outer sleeve of the plug cured the problem. If you earth the casing of your radio with a lead from a known good earthing point, and the interference lessens, then its definitely an aerial coax. lead fault. Check the braiding has'nt broken where its connected to the actual plug. These faults are usually caused by bad earth braiding connection at the aerial end or if your lucky like me at the radio end. Very seldom in the middle of the lead.
shaunthesheep
kathbert,
will check what you tried, does anyone know where i can get the key which sony supply to remove the stereo, without removing everything around it??
dom <img src=icon_smile_big.gif border=0 align=middle><img src=icon_smile_big.gif border=0 align=middle>
spanners
Unread post by spanners »
there is also a supressor on the coil small square black ceramic unit connected to one of the coil wires. also check that the earth straps are in good condition on the bonnet hinges.
