pug stereo problems anyone help asap?
neilsxm
Unread post by neilsxm »
hya,
i've a 405 quasar diesel the radio has been disconnected and i've entered a wrong code in 3 times and now the radio is showing SECURTY on the display,but i've just rung the dealer and they've given me the right code,is there anyway of clearing the SECURTY so i can enter the RIGHT code
any help/advice will be gratefully recieved
cheers
neil
tonespeed1999
Unread post by tonespeed1999 »
cant be 100% sure!is it a clarion unit?
try leaving the ignition and stereo turned on for at least 30 mins.
the stereo should reset it self enabling you to put in correct code!
PowerLee
Unread post by PowerLee »
You get 3 attempts at putting the code in, Get it wrong & it locks out for 30 minutes & displays "SECURITY"
Leave the ignition on untill the radio resets.
NOTE: The lock out times doubles after every 3 wrong codes are entered, Put 3 more wrong codes in & it will lock out for 1 hour, Then 2 hours, 4 hours etc.
neilsxm
right i'll give it a go and try not to mess it up!!
cheers
neil
neilsxm
hya again,
right had the radio on now for over 1 hour and it's still showning SECURITY on the display,but i've only entered the code in wrong 3 times
any idea's?
cheers neil
PowerLee
Hmmm, Never had "SECURITY" up on the display for more then 30 minutes myself, I have had the radio go in to french! I got "SECURICL" or something similar, lol
Try pressing a button, Button 5 or the BND / Band button, Switching it off & back on.
Or try leaving it a little bit longer.
neilsxm
hya again
Cooking on gas!
Cheers
