XM managment software
wonderd
Unread post by wonderd »
Does anybody know where can i get a managment software for the XM that i can load to my laptop?
Elad.
ActivaV6uk
Unread post by ActivaV6uk »
(I'd like this for the activa too if any one knows ware to get it)
Andy
Mosser
Unread post by Mosser »
Me too please!,
I've got the full diagnostic and management software and interface for Seat, Audi and Skoda's, but havent found anything for Citroen so far
wonderd
I got intouch with a cit. dealer here and he might lend me his diagnostic gear for the weekend...
I am still looking for a software though..
Elad.
tonyg
Unread post by tonyg »
Hi
The Gunson tester will download the fault codes from an Xm.
Tony
wonderd
What is Gunson tester and where do i download it from??
Elad.
FrenchLeave
Unread post by FrenchLeave »
OK, I'm mug enough to ask. If you can download the management software to your PC, what are you going to do with it?
wonderd
If i have the software on my laptop, i can buy the correct cable and connect it to the car's computer...
Sounds logical enough???
Elad.
ActivaV6uk
if you can get this woring then you can check out problems as they happen also you cna do in depth testing of the cars systems and tell if a fault is lightly to occure. i've been after this for ages, but to my knowlage no one dose anything that you can put onto a laptop.
Andy
NiSk
Unread post by NiSk »
jeremy
x 3
Unread post by jeremy »
This any use? Your cars may not be on the standard but future ones will be. I seem to remember there are cables etc somewhere on the site.
jeremy
ActivaV6uk
its a stanalone fault finder, it would be nice to find one that works like the VAG ones ware all the sensor readings are avaalbe and viewable in real time. i cant remember what the modual is called.
even the BX's ecu is readable on that system that is linked above. it basicaly uses a morse coad type output from the memory stored on the ECU.
Andy
FrenchLeave
Thank you, Wonderd, for the information and please excuse my ignorance. I assumed by "management software" that you were referring to the program that was loaded onto the engine management chip, which takes in various parameters like engine speed, air temp, throttle opening etc and uses that info to control fuel flow and ignition timing. I had visions of you altering the program and reprogramming the chip!
jeremy
x 3
Looks like the link I intended to post didn't come out
http://www.scantool.net/index.htm
jeremy
wonderd
Thanks jeremy, that looks like something i could use but i am not sure it will fit to my XM even though it's an 'advanced' 3 liter one...
Elad
