Oils ?
Twiss
Oils ?
Unread post by Twiss »
A question for All (I think)
Which is a better oil for a 1.9TD? ( XUD9TE )
Total 7000 quarts
Castrol GTD 10w/40w
Mobile 1 0w/40w
Dave Bamber
Unread post by Dave Bamber »
Out of the three, I'd go for the Total, only because it's OME. I think the Mobil might be over doing it a bit.
I tend to go for a cheaper semi synthetic and change it every 5/6000 miles. I'm using a brand called Planet at the moment which meets all the latest specs for turbo diesel and is silly cheap. It's made by Comma which, correct me if I'm wrong is owned by Shell.
wilkobob
Unread post by wilkobob »
I use Castrol GTX Magnatec in mine (a mate of mine rang Castrol, and they say its exactly the same as the GTD Magnatec, just a different lable). As above the Total is the stuff the manufacturers recommend, but where I live GTX Magnatec is available and its £18.99 with a free baseball cap, and Ive had no bad experiences with Magnatec.
dillosk8ter
Unread post by dillosk8ter »
About to but GTX Magnatec in my BX {prob. tomorrow}...got it for £15.99 {4.5L).
madasafish
Unread post by madasafish »
GTX Maganatec is not synthetic or semi synthetic.. Imo Planet is better oil
arry_b
Unread post by arry_b »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by madasafish</i>
GTX Maganatec is not synthetic or semi synthetic<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
[fx: nods]
Aye, £3 quids worth of oil in a flashy container, with a very strong brand name.
FWIW, Tesco were selling a high spec CF4 / ACEA B-3 diesel oil suitable for Turbos for a ridiculously cheap £2.99 / 5 litres a couple of weeks ago. Looked and smelled like Esso product to me, and the ZX is running fine on it.
crapday
Unread post by crapday »
GTD Maganatec is only £11 in cosco in glasgow
RDD
Unread post by RDD »
Unipart 15w/40 works fine for me :)
Kowalski
Unread post by Kowalski »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by arry_b</i>
[quote]<i>Originally posted by madasafish</i>
I tried Tesco's semi-synth diesel engine oil in my '95 Xantia and after 6000 miles it was very thin, so I didn't risk it again, i went back to Comma Eurodiesel. I've tried a few different oils and the Tesco oil was the only that I wouldnt use again.
Thunderbird
Unread post by Thunderbird »
My HDi prefers Total Quartz 9000 0W30 or 5W30.
Quite superior to others in terms of viscosity.
Viscosity at 40 and 100 ºC (mm2/s):
Quartz 9000 0W30 or 5W30 __ 53 and 9.6.
Quartz 9000 5W40 __________ 85 and 14.
Quartz 7000 10W40 _________ 100 and 14.5.
Quartz 5000 15W40 _________ 110 and 14.5.
Quartz 3000 20W40 _________ 154 and 17.
oilyspanner
Unread post by oilyspanner »
Both of my TD motors run on Castrol GTD, only because I have a source, otherwise Morriss semi synthetic. frequent changes are the rule too.
Stewart
