405 outside temp sensor
matt
Unread post by matt »
Does anybody know where the outside temp sensor is on 93 405 stdt?Mine never read correctly but has now stopped working completely.Thanks.[?]
PowerLee
Unread post by PowerLee »
Hi
Have a look under the passenger side door mirror, Your looking for a small raised black button.
Thats the sensor, You need the mirror glass off to change it, Tilt the glass all the way upwards, Look through the gap at the bottom between the glass & the housing, See that wire locking clip? Unclip that & the glass will lift off.
The sensors are just clipped inside the mirror housing & £18 new from Peugeot, Part number: 6445 F9
The only snag is the sensors wires are taped to the other mirror wires all the way back to the 2 connector plugs inside the door.
I would have a hunt down the local scrapyard, Plenty of Peugeots & Citroens to get one off.
matt
Cheers for info,sounds like an excuse to rumage in my local breakers yard!
