Would burnt valves cause excessive diesel knock?
engine is from xantia, now in 306 xldt and the pump has been changed for the 306 unit, but its a real pain to start, and when it does start, it idles ok, but whenever you try to rev it, it knocks quite a lot, although it doesnt sound like a normal diesel knock, pump timing and valve timing seem to be fine, what can it be?
knocking diesel
tonespeed1999
Dave Burns
Burnt valves wouldn't cause diesel knock to get any louder, quite the opposit since they would rob the cylinder of some of it charge under compression, burn valves will however give you starting trouble for the same reason.
A stuck open injector will make a hellish racket when the engine speed is raised from Idle, crack the injector unions one at a time to pinpoint the affected cylinder.
Worst case scenario would be a hot spot (swirl chamber) on the move, being mashed about by the piston, this or some other mechanical failing could be likely if the noise can't be temporarily stopped by cracking open the unions.
Dave
Dave
martyb2
christi
burnt valves cause difficult starting and clouds of smoke when running cold due to the lack of compression
a leaking manifold won't cause difficult starting, but it could make a noise
maybe you retard the timing a little and see it becomes quieter
also it could be a dripping injector
a missmatch of parts won't cause it to knock
rossd
rossd
