Air con Switch
jonn
Air con Switch
Unread post by jonn »
Does any one know if the aircon switch on off tell- tail light is part of the compressor power supply ?. I ask as mine failed at the same time as it stoped(the compresser).Any idears anyone?
Thanks for all replys, another switch fitted now no probs with air con
tonespeed1999
Unread post by tonespeed1999 »
the tell tale light should work whether the system is functional or not,check the fuses first,it might be the bulb in the switch thats blown.
np
Unread post by np »
When my a/c dosen`t work on cold days(i.e you switch it on but the temp is to low for it to work,meaning the compresser dosen`t work)the switch still lights up.What car is it?
jonn
by the way its a xantia 1.9 td sx
np
Unread post by np »
If its a mk 1,upto `98,the only a/c fuse is F12,10 amp,in the facia fuse box.But this also covers heating,a/c,cruise control,hydractive suspension,alarm system,alarm siren & instruments.
So if any of them work,its not the fuse.
If you have the 98 on mk2,facia fuse box F14 5 amp.This covers the a/con & fuel injection ecu.
