Hi
I'm looking for help on an electrical problem on my 99 2.0 Hdi xantia
The car is a non starter on my drive but the speedo reads 130mph and the rev counter reads 6000. The fuel guage is dead, the radio is dead - when the indicators are put on the clock, the interior lights (when doors open)and the door open warning light flash in sympathy and both the speedo and the rev counter also move in sympathy - this does not happen however when the indicators are being activated by the hazard switch. I guessing that the non starting is due to immobiliser being activated
I've already checked the earth points by the battery and either side of the central consul without success but I dont know if there are any others and the manual's no help
Any suggestions welcomed as I'm close to resorting to Citroen
Erratic electrics on Xantia
tonespeed1999
RStacey
Hi - thanks for the reply
The battery is nearly new and fine - engine cranks well - battery connections checked ok - the first sign of a problem was the night before it failed to start when the speedo and rev counter went haywire briefly, the clock and radio reset themselves as if the battery had been disconnected and the fuel gauge read zero briefly. The car however drove perfectly and all the gauges settled down again
weety
