When I start the cold engine of my dyane, or when I push the pedal accelerator with the engine at minimum, the engine produce one explotion and the air filter is pushed out from the canister.
Which is the reason of this problem??
Dyane problem
rabenson
tonespeed1999
back firing and pushing the air filter out was quite common on the dyane and 2cv.changing the points and condensor behind the fan will cure it.the ignition needs to be set spot on.if you know what your doing they are easy to tune.make sure you have a detailed manual.as a citroen specialist for 20 years i always used a dwell meter and timing light.
Stinkwheel
adamskibx
Yes it will almost definately be the valves or the ignition. If you check these bits systematiacally then the problem should be fixed and if it is just a case of Dyanes and 2cv's doing this when cold you wont have wasted your time unless youve done these jobs in the last 3000 miles anyway. I have to admit I never came accross this in my 1 and a half years of driving a Dyane everyday so I would suspect its one of these two problems.
Stinkwheel
dmac
yangreen
