Hello Everyone,
My 2000 Xsara hdi sx has developed the dreaded yellow-flashing-airbag-warning light problem. I know from some posts on here that it probably has something to do with the wiring under the front seats and I have been fiddling around making sure everything has a tight fit......the problem goes away but then comes back again.
There are a yellow, brown and a green connector under the seats as well as a bigger black connector under the driver's seat. Does anyone know how to stop the light....which wires do i need to cross? Any help would be gratefully received!
Thanks,
jochem
Xsara airbag warning light
- x 1052
jochem
drpau
Im living with mine at the moment. It seems to come in cycles. Initially the side airbag light will be on for a few weeks, then this will go off and the 'airbag' light starts flashing for a few weeks, then it stops and I get no lights/flashing for a few weeks then it starts again. Will have to get off my backside I suppose - there is no space under there though is there!
Cheers
Paul
Cheers
Paul
- x 1052
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jochem</i>
What is the yellow wire for....do you know?
im pretty sure the yellow plug is for the seatbelt unfastened warning lamp.
jochem
