Xantia 1.9 Turbo Diesel
soupy_sam
How do you know if the Turbo is working?
jeremy
Point it up a steep hill at about 50 in 5th put your foot down and enjoy!
Should pull very well indeed over 2000 revs is the answer. If you are seriously in doubt disconnect the extra fuel device supply. There should be a thin pipe leading from the intercooler to the injection pump. If you disconnect this pipe the turbo will blow as normal but there is no additional fuel and so no more power. If you can't tell the difference it isn't working.
Jeremy
Jeremy
- x 1468
nridley
