Not to steal barneysvage thread, I'm having some problems of my own....
Not long aquired a '95 M-reg Xantia 1.9TD LX for the princely sum of £1 (I know, but I can't resist cheap cars!)
Suspaension was shot, so I put on new suspension spheres at all 4 corners, but I can't get the rear height corrector to work properly. When the control rod is connected up, it operates in totally the opposite direction!!! Set the lever to min, the front goes down, but the back goes up, and vice-versa..... It will also lose pressure gradually if set to any position in between min and max, and the back end sits right down. I've tried 3 different rear height correctors from a breakers now, and all do the same! Fresh LHM has been used, and it's beginning to drive me nuts
Any help/pointers/advice/reassuring noises much appreciated!
Another Xantia rear suspension nightmare!
