I'm intending to replace the rear discs and pads on my Xantia. I've read the Haynes bible and it would appear to be fairly straight forward[?]I've also checked the various threads here on the forum and have noted everyone elses experiences of doing the job. One question remains. According to Haynes once the caliper bolts are out you can support the caliper with string etc or rebolt it temporarily to the arm until the disc has been replaced. Is it ok to do this? Will there be any strain on the pipe. Does the pipe need to be removed. If the pipe was left in place there surely wouldn't be any need to bleed the brakes. I'd appreciate advice on this.
Den
Rear disc renewal
jeremy
bxbodger
den
