BX w/wiper prob.
mikeg
BX w/wiper prob.
The wipers wil not return to the park position when switched off, nor does the intermittent selection work. It's ok on normal and fast speeds and the washers work when using norm/fast but not when using wash/wipe. I'm not too well up on electrics, so can somebody advise, please? Thanks.
tonespeed1999
jeremy
Sounds like a faulty switch to me. Worth checking that the various plugs are fitted properly first as I've never seen anyone complain that the switch had gone wrong before.
My reasons are that the wiper motor and the washer motor are entirely separate components, both of which are working satisfactorily in most respects, with some functions not working. The switch is the common component.
jeremy
jeremy
DLM
prm
It could possibly be the park wiper contact inside the motor as tonespeed mentioned.
If you remove the complete motor and mounting bracket assembly. Remove the gearbox/drive cover, underneath the main gear, you should find three ?? brass finger contacts. Slow speed, high speed and park. If you clean the circular contact strips and slightly raise fingers to make better contact. Park contact may be burnt at fixing point and quite delicate when raised.
Ian Fearn
vanny
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
I've never seen anyone complain that the switch had gone wrong before.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
I swapped three different stalks on mine to resolve a problem where the washers wouldnt work, then i had a revelation one day and pushed the conection at the washer bottl a little harder and they have worked ever since!
So there you go Jeremy, you still hevent ever heard of a problem with the washer stalk on the bx! [:D]
mikeg
Ian Fearn
Ian Fearn
mikeg
