Xantia ABS problem
Huwbruin
Xantia ABS problem
Unread post by Huwbruin »
Hi
I'm trying to locate an ABS fault on my '98 Xantia 1.9TD SX.
Can anyone please tell me which terminals of the ABS ECU relate to which ABS sensor?
ghostrider
Xantia ABS problem
Unread post by ghostrider »
Can't find the Xantia ABS Diagram however it may be more or less the same as the Late BX one in which case the pin nos are LH Front 5&23 RH Front 7&25 LH Rear 6&24 RH Rear 4 &22 Pin 1 should be earth 9 & 10 should be linked as should 19 &26, there is a diode between 20 & 27 which you could check to see if the Pin outs are the same
Pete
________
Stewing
Huwbruin
Thanks Pete
I've had a look at the multiplug on the ECU but it doesn't seem to be the same as that on my old BX GTi.
Anyone else got any ideas or does a trip to the garage beckon?[:(]
Jon
Unread post by Jon »
Huwbruin
Many thanks Jon!
