Hi, I just put a full set of autometer gauges into a 306, so far its been succesful but came up against a couple of small queries.
The gauges came with senders but 2 of them dont fit, oil pressure sender and coolant temp sender. Both are the single wire type senders, will the standard pug ones do the same thing? If they will would any pug / cit oil pressure sender fit as mine was just the oil pressure switch type unit. Its a pre 97 td [:D]
