folks,
regarding my privious posting about rear trailing arm bearing replacment. is it advisable to remove the hydralic spiral located before the 24mm nut??, or using a 24mm deep socket to go throught the centre of the sprial??, if possiable.
i will be spraying the nut a couple of days before i start the work, so the wd40 can penetrate all the way throught.
cheers
dom
trailing arms - xantia
Aubrey Smith
shaunthesheep
