picasso rattle in doors
schummy10
Unread post by schummy10 »
hi iv a citoen picasso 2001 2.0hdi and having problems with rattles and bumps which seem to come from doors when you go over uneven roads they seem worse when there is people in the back im sure the noises come from the doors and not the suspension anyone else have similar problems and know solution?
schummy
Richard Gallagher
Unread post by Richard Gallagher »
Apparently the rear door seals on Picasso's are a source of rattles and squeaks. Solutions include spraying a rubber lubricant over the rubber seal to sticking sellotape to the surface of the seal where the door closes onto it.
schummy10
hi was out there looking at the back doors richard and i seen that the door keepers that are attached to the arches appear to have like a backing plate to them and they have started to pull through the body ie arch and have started to leave holes.if that makes sense!!
schummy
