Seen a few refernces to poor earthing on the 405s. Got a list of the earthing points but not seen any info about a fix. I *assume* that all you need to do is make sure that these earthing points actually *earth* (good cable/connections etc) and/or run a longer cable to a good earth point?
Cheers in advance.
405 earth fix?
PowerLee
Hi
Normally you just undo the 10mm bolt, clean up the paint behind, a small amout of copper grease & stick it back together.
However, If you have the nasty plug on earths there is a modification you can do.
CUT THE SODDING THINGS OFF ( What a crap design! ) & crimp + solder some ring terminals on, Remove the earth fingers from the body shell & use the 10mm bolt & a serated washer to put it back together.
dvhttn
PowerLee
Hi
The earth fingers are awful, The ring terminal & serated washer is so much better.
Also the battery terminals are rubbish too, A pair of round clamp terminal is much better, But you would need a beefy soldering iron to solder those on, Or remove the leads from the car & use a blow lamp.
One other thing, Depending on how old the 405 in question is, If you want to see a really really rubbish design, Take a look at the 3 large loom connectors behind the passenger side headlamp.
Male terminal against another male terminal, They never give any trouble ( Yeah right! )
dvhttn
PowerLee
dvhttn
Mines a GTDT (urbo). After your post I checked and it does have the extra bulb so that explains the superb lighting on main beam.
The battery terninals/earth connection look sound as well so maybe someone has already sorted that out but I will check more closely when it gets a bit less miserable on the weather front! It all works at the moment ...
Cheers
Cheers
PowerLee
fastandfurryous
- x 4
