water and oil leaks on xantia 1.8
deano
Unread post by deano »
Hi
picked up a xantia esate from an auction today. Noticed when i got it home that it's leaking oil, quite a bit regulary onto the exhaust. I would think this is caused by a the rocker cover gasket? Was getting dark at the time so could not check fully. Is this a common problem.
Also there is a water leak from the drivers side, would this be the pump on its way out or a seal or something?
other than that it appears to be in good nic :) has done 89,000 miles.
Any thoughts suggestions would be most appreciated, save me worring to the morning.
Cheers and thanks in advance
Deano
oilyspanner
Unread post by oilyspanner »
Rocker covers are prone to leaking, the water pump is on the offside so it is a possibility but would warrant further investigation
stewart
deano
Hi
thanks very much for the the reply, will have a look at the rocker cover and will investigate the water pump, when i've got some light.
Deano
