Up the Suwannee
Stempy
Up the Suwannee
Today I was driving my Xantia along happily when the red stop light came on along with the brake warning light. I ignored it as you do as the car continued to behave normally, but after a short time the car gradually began to sink and the brakes slowly got worse and worse until nothing at all, so then I had to stop. Checked for lack of LHM but tank seems full. RAC were called and car was put on the back of a truck. I'm now at home sulking.
It's dark and snowing so can't get out to check anything and not sure where to start anyway. I'm assuming the pump might have packed up, but how would I check? Suspension is bottomed out and wont pump up, which gave the recovery guy a few problems loading it. Brake pedal does nothing but I can slowly move it around the drive using the handbrake. Can anyone give me inspiration. Tomorrow I'll probably have to hire a car to get to work 'cos I ain't using the bike this weather.[:(] Bugger bugger and pants.
Richard Gallagher
Stempy
Richard Gallagher
ItDontGo
Richard Gallagher
I would have thought that the fact that the car sank must be indicative of an internal leak on the basis that if the pump just stopped working the anti-sink valves would click in just as if the engine was stopped and therefore the car would still be at normal ride height.
As mentioned above have you taken the filler cap off the LHM tank to see what the LHM is doing when the engine runs?
Stempy
Thanks Richard. Funny you should mention compatability. The MAP sensor you sent is listed as having the same part no. as mine, but although it is the same shape and will fit onto the manifol the electrical connector is different.
Anyway, back to the subject in hand, I'll have another look in the morning and see what I can find out, I think there was the odd click but can't be sure. I did look in the tank with the engine running and it didn't look like there was any movement of fluid, though I've never looked in there while it's running before so don't know whether you can actually see anything happening.
And BTW, the front seemed to sink much more than the back if that makes a difference.
AndersDK
The system pressure will slowly disappear during drive if the pump does not build up pressure. Thus the antisink valves does not do their job as it resembles the driver is changing the height on purpose.
It could certainly be the pump at fault - but try first if it simply lost the feed because of an airleak in the feed hose.
I think it's normal for the front to sink first as it is heavier. My BX does this if I set suspension to lowest.
Richard Gallagher
Stempy
DoubleChevron
Do listen to Anders ... He's a very smart person
Seriously check the feed line from the reseviour to pump extremely carfully, if it has loose clamps/splits/cracks it will suck air and not pump fluid.
After you have very carefully checked this line, pull the line off from the reseviour, press a funel into it and fill the funnel with LHM. This will prime the pump, hopefully if you do this it will start pumping again. If it does, quickly plug it back onto the reseviour
I've never heard of any hydraulic Citroen pump just stopping like that. Usually they just get slower .... and slower ..... and slower ...... you get the idea.
I put $$$$ on it sucking air. Possibly the filters in the tank are completely blocked if the LHM has never been changed.
seeya,
Shane L.
seeya,
Shane L.
Stempy
Well heres the update. Having calmed down a bit and had a look at things properly this morning I removed the pump feed pipe from the tank end and there seemed to be very litle fluid in it (the pipe)so I assume it must have sucked in air from somewhere. Having reprimed the pump it immediately began to pump up, then the wierdness began!
The steering began to vibrate when the wheel was turned although this gradually got better and has now stopped. Now it seems the rear suspension will not go directly from fully down to fully up but will work if you go up a stage at a time although the front shoots up and down like a good 'un. Looking in the LHM tank there seems to be a flow of fluid but it looks a bit airiated, don't know if this is normal. Brakes appear to be ok. Pressure reg clicking like it should.
Stempy
Well the Xant got me to work and back today without a hitch, 60 mile round trip. Still not entirely happy with the rear suspension. Done some Citaerobics but it's still not rising quite how it should. Plus the vibratey steering wheel happened once more, but only for an instant. Hydraulics eh! Give me electrics any day, much easier to understand. Guess I should be looking for an air leak somewhere.
Stinkwheel
