while i have at least average DIY skills & am not worried about tackling most mechanical jobs, i have very limited experience of car faults/problems so need some experienced thoughts on my latest worry...since i got my xantia the steering has always had the slightest pull to the right.but just lately,when steering left there is the most awful cheeping sound coming from i think the drivers side front wheel...only way i can describe it is like a bird chirping
any ideas on what the problem could would be appreciated
cheers
jake
xantia going cheep
alan s
- RIP 2010
- x 6
jeremy
Could also be a wheel bearing - may make a difference if you apply the brake while turning, re-distributing the load slightly may change things.
Alan's suggestion of brakes could be the cause - I'd start by taking the wheel off and having a good look around - and check that the handbrake cable isn't fouling the wheel rim while you are there!
Jeremy
Jeremy
jakeuk
Richard Gallagher
jakeuk
its sorted......
got 2 new tyres as recommended at MOT...had asked for tracking to be checked which the guys duely did for me and as suspectected it was slightly out,(we're talking milimetres)just enough to cause the slightest pull to the right but more annoyingly that bleeding cheep cheep noise when turnining left or even when merely correcting left from the right pull.
now u might say i'm easily pleased but i had smile from ear to ear all the way home from the tyre shop.[:D]
once again ... a big THANKS for all your help[:)]
