MOT failure
chriszx
MOT failure
hi all - zx just failed MOT on right rear brake, footbrake and handbrake - its working, just not enough to pass, wheel turns ok when brakes off and works enough to stop it turning by hand when on, is this a seized piston?, or is it the pressure limiting device?, if its the caliper is it worth rebuilding or should i just get another (its the bendix)- ta.
oilyspanner
chriszx
oilyspanner
bxbodger
Silly question, but have you actually had the wheel off for a look?- you could just need a new set of pads and a disc.
MOT brake standards are pretty appallingly low compared to the tests obsession with emmision levels, and you can still pass with virtually no meat on the pads and a disc like paper- you may have gone beyond this....Its also worth ckecking that the hose hasn't collapsed internally, try bleeding some fluid through-it should flow easily.
chriszx
yeah, i've had a quick look at it, its had new discs and pads fairly recentley and there's plenty left on both, the hose is also ok so i'm assuming its a bit seized, its a slighly tricky thing to sort out as i'm not going to be sure its fixed until i get it re-tested as its strong enough when you're grabbing hold of the wheel and i've never noticed a problem driving it.
