The blower on my newly aquired Picasso only works on full blast. The Dealer is going to book in to investigate but I fancy a go myself..
Question is...where is the blower.
Is it likely to be the motor or an electrical fault??
Blower Resistor Pack Location????
gjb02
Follow up report :
Ok, I found out (Haynes & the forum) there is a resistor pack seperate from the motor.
Thing is, with the dash in pieces as far as I'm willing to go at the moment[V, the resistor pack appears to be seperate from the car!!
I follow the wiring loom, then it takes a turn into the unknown, then re-appears with 5 more wires, etc.
Please, anyone with the knowledge of the exact location of the heater blower resistor pack on a 2001 Xsara Picasso, please help! [:)]
gjb02
Found it!![:D][:D]
I had to take out the blower motor! It was only then I could see the resistor pack located in the central bulk of the dash, downstream of where the fan was.
The resistor was a twist-2-lock assembly, once twisted it fell into my hand and I was able to remove the wiring plug from it.
It looks like, as mentioned previously, that the thermal fuse portion had blown. I bridged it with some heavy gauge wire...and it now works a treat. Sorted.[8D]
Mosser
gjb02
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mosser</i>
you really should put a thermal fuse back in the circuit somewhere as you are risking a fire if you just bridge it with wire, you can get them from maplins quite cheaply if you fancy a bit of diy
What is the exact type/rating of the thermal fuse required? Better still a catalogue reference would be great.
Diy, not a problem now I know where to find it![:D]
Mosser
