Flat battery after freezing nights
modi
Flat battery after freezing nights ... but works fine in non-freezing weather, is it a faulty battery indication??? thanks
oilyspanner
Kowalski
The battery on my '97 Xantia looks fairly old, possibly its the original.
When its very cold, the battery will barely turn the engine over if I don't wait for the glowplug light to go out. If I do wait for the glow plug light to go out it turns the engine over happilly. Turning the glowplugs on must warm up the battery... in warmer weather the battery is fine.
JohnD
- x 72
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>
So it doesn´t owe you anything. The battery on my 1998 Xantia failed just on three years old. Although my 1998 Saxo is still on original.
modi
ItDontGo
Sounds more like the battery is struggling to power both the glow plugs and the starter at the same time. Or am I mistaken?
G4EIY
Hi Modi,
On one of mt BX's, I made an insulation cover for the battery out of polysyrene sheet, held in place with nylon strapping.
This will help to conserve the heat in the battery on those cold nights...
Don't forget to depress thew clutch pedal while cranking...
But in your case, it sounds like the poor old battery is on it's last legs...
Cheers
Brian
Cheers
Brian
Kowalski
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ItDontGo</i>
Sounds more like the battery is struggling to power both the glow plugs and the starter at the same time. Or am I mistaken?<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
No, the battery can power both at the same time, the glow plugs stay on long after the light goes out (havent you heard of afterglow)?
I think my battery will need replacing soon, but not just yet. This winter didn't kill it but perhaps the next one will. The car gets used 6 days a week, generally on long enough journeys so keeping it charged must be the secret to a long and healthy life (at least as far as a car battery is concerned).
oilyspanner
druist
paranoid
https://secure.gsfcarparts.com/shop/results.asp
Extremely decent batterys as well!!!!!
