i have an opertunity to buy a 1992 XM, the owner said that he didn't move the car in 3-4 years, because he has a big problem with the steering - some box under the car??
does anybody know what he is talking about?
he said that the garage replaced the gearbox and that caused the steering a serious damage..
what do you think?
BTW, it's a fully automatic 3.0 liter engine
How much is a 1992 XM worth??
AndersDK
I think the owner gave up too easy on persuading that garage ...
Honestly - I believe this XM still have the old type PAS servo - which includes the FDV which may be the problem.
Donno for sure on the XM - but me thinks this FDV has to be removed if gearbox is going out. And then the garage could well have swapped a couple of pipes leaving the thing useless even damaged because of overpressure ...
No matter how you look at it, it means serious fiddling before the car is driveable. Spares could amount to a couple of 100's.
In my opinion the owner should pay YOU to get rid of this useless car, which would be a double fortune to repair (in that same garage [}:)] )
On the other hand ...
If the the car otherwise is in good nick - and defo no rust - then things tends to be a bit on the easy side to sort out for the DIY'er.
tonyg
wonderd
tonyg
