When driving along normally I often have the 'computer error light' illuminates on the dash. The car then sticks in gear or may change down from 5th to 3rd (on the mway). The owners manual suggests that the car must be taken to an authorised dealer but obvoiusly I'd rather not if the problem can be rectified myself. has anyone else experienced this or have any suggestions/remedies I might try?
Regards,
Slim
1994 Clio 1.4 RT Auto: Computer Error Problem
mark c
danielsydney
ferkemall
- New User
Re: 1994 Clio 1.4 RT Auto: Computer Error Problem
This the vicosity sensor in the gearbox it triggers limp mode when the fluid gets to to thin because its to hot , get the fluid changed , renault sold these autos saying the fluid never needs changing just topping up ,any auto gearbox MfG will tell you to change the fluid at 30,000 miles because the debris from the clutches and steel spacers blocks up the valve body /EMV valves /screen filter and torque converter lock up , they made a lot of money with their just top it up sales pitch ,
Modus owner who went against their advice and flushed his gearbox out and used another top spec fluid that was cheaper than renaults
that was 2 years ago car still drives like new !
