Xantia 1.9TD starting difficulties
Huwbruin
Unread post by Huwbruin »
Hello
Can anyone point me in the right direction?
My 98 Xantia TD has suddenly become difficult to start.
It will turn over fine and catch on all cylinders then immediately cut out.[:(]
It will then turn over without starting but will eventually catch and run as if I had tried to start it without letting the glowplugs do their job.
This started a couple of weeks ago, out of the blue ( before this there was absolutely no hint of a problem - it started first go and ran immediately on all four cylinders).
This makes me think it is not the glowplugs themselves.
Any ideas?
John
oilyspanner
Unread post by oilyspanner »
Try squeezing the fuel primer bulb until it gets firm before attempting to start it, if it improves it then you have an air leak somewhere, other thing to try are operating the glow plug circuit twice, if this improves it then it might be glow plugs, while you are under there try draining any water out of the fuel filter.
Stewart
Dave Burns
Unread post by Dave Burns »
Firing for a few strokes then cutting out is deffinately caused by air in the pump, check the leak off pipes and end cap for cracks, check also the return pipe and supply pipe for leaky joints.
Dave
Huwbruin
Thanks Stewart, thanks Dave.
