Xantia Loss of Power
cruel_kindness
Unread post by cruel_kindness »
New to this forum so hello all!
Just got my xantia back from the mechanics sorting about oil leaks, i believe he changed the rocker box cover gasket. Driving home, accelerated onto a dual carrigeway and heard a pop noise and lost all turbo. Opened the bonnet and saw that the pipe leaking into the intercooler running down the front of the engine had come off. I re-attached it and tightened the jubilie clip, had turbo back but the car doesn't seem as pokie as before. Is there anything that could have happened to cause this?
Kowalski
Unread post by Kowalski »
Is the pipe securely attached now? If it isn't you could have a leak which could be losing some boost but not all. Either that or when the pipe blew off it damaged itself or something else on the intake system e.g. intercooler etc.
cruel_kindness
im sure its on securely on now and no damage was done. Is there anything that could have happened when the rocker box cover gasket was replaced? Maybe i'm just being paranoid and the car was always like it!
Kowalski
There is a little pipe which goes from the halfway along the large pipe from the intercooler to the inlet manifold to the fuel pump. If this pipe isnt plugged in correctly you will get a distinct lack of power "on boost", since this pipe allows more fuel when the turbo is boosting.
np
Unread post by np »
I`ve had the same problem on mine.Peugeot forgot to tighten it when they did my cam belt,& i`ve forgoten about it a few times as well!Do`h!!!
