306 whistle/whine through vents & stalling
TomH
A curious problem has developed where when the car is warm and idleing a whine can be heard in the cabin coming from somewhere behind the dash (glovebox area) which every now and then gets louder as if it is whistling though the vents. It then stops when you drive off, so only at very low revs. Just wondering if anyone had any ideas as it is annoying! It also rattles down there for a couple of seconds when I switch the ignition on.
TomH
OK the whine is getting worse, and happens at low revs.
A couple of times when the car has been hot and stopped at traffic lights etc I have turned the fan on to see if it stops it which it does briefly, but if I turn the fan on too fast and then off again the revs drop drastically and stall the car!! The engine management light comes on and it won't start again for another 10 seconds or so. Any ideas? [:(]
edit: could it be related to the alternator? dash lights and headlights also seem to flicker
yangreen
