Xantia Passenger Door Mirror cables
soupy_sam
Unread post by soupy_sam »
Hi
I have a xantia and the manuel mirrors do not adjust as the cables are not attached to anything behind the door facia.
Do the cables come seperatly from the mirror or does it come a a kit.
Whichever way how do you replace the existing cable, and set up the mirror so it works with the adjuster.
x 1431
New manual mirror comes complete with cables and the 'control box' that fits on the inside of the door. To change you need to remove the door trim panel, the alarm sensor cover panel, and then the mirror. Feed the new cables in and screw it all down. Took me a couple of hours to change one on my previous Xantia.
