ZX Brakes from Berlingo
DarkendViper
Unread post by DarkendViper »
Hi all,
Just a quick question. I've been offered a set of berlingo brake calipers. I'm interested on fitting these on my ZX. The calipers are Lucas i've been told. Will these fit on? Also would I need the caliper mounting bit and if so whats it's technical name?
Many Thanks
Ste
rossd
Unread post by rossd »
Yes they should bolt straight on, providing you have at least 14" wheels. The caliper mounting is the carrier, you will need these too.
rashmore
Unread post by rashmore »
Yup, they will bolt straight on. Need to ensure what 'mark' Berlingo they are off as mine were off a mk 2 which meant different size and gemometry of brake disk (same as pug 607) to berlingo mk1, which caused me no end of hassle - search for previous post under my name on the matter. back from hols so if get time will search and post the link - work/time permitting.....
Jon
Unread post by Jon »
If you use Girling calipers from a Blingo upto RP9127, they go straight on. You also need to use Berlingo brakes hoses as the Zx ones are too short.
