Head lights is it me?
Stuart McB
Had the wifes car this morning Reno Megane Convertible (2001 mod) [:D] any how when going from dipped to main beam I noticed that the dipped stayed on. Now my Xsara I have noticed that going from dipped to main beam, the dipped turns off and I have this very faint dark area in front of the car. No big problem but just wondered. Is this the Xsara's old stlye head light bulbs, one bulb for both positions, or is it the Meganes newer seperate bulbs for all positions. Any info appreciated as nothing in the book of lies or owners hand book.
Thanks [:D]
Thanks [:D]
Dave Burns
Lots of cars have h/lights where the dip remains on when main beam is on, xantia and zx for instance as these cars (not all zx) have the twin H1 setup, one bulb one fillament.
Any twin fillament bulb will have the dip switched off when main beam is used, I would have thought a Xsara vtr would have twin H1's too, has it got H4's or something more exotic.
Dave
Dave
Stuart McB
oilyspanner
john alexander
NiSk
If you run an H4 (or any other twin-filament lamp) with both filaments alight, it will burn out very quickly. Sure, it will give you more light on high beam, but at the cost of overheating and metal migration causing one of the filaments to depleate onto the other.
Which is one of the resons why most modern cars have indivual light sources for high and low beam (the other reason being that the shape of the reflector/lens can be configured to give the best light output for that beam shape).
//NiSk
//NiSk
Forth
Do you mean these horrible new ones which blind not just oncoming drivers but their passengers as well, regardless of whether the beam that's on is the dipped or full?
As in, these comparatively small, high-intensity round ones that appear to change in visible spectrum as the angle of approach changes?
Serious dazzlers which are legal and increasing in number with new cars, despite fog-lamps --- properly set up, lower level, safe and no problem to anyone -- having quite absurdly and inexplicably been banned (presumably by some anonymous committee of profiteering stazi apparachiks too power-drunk to appreciate the difference between fog-lamps and misaligned auxiliary floodlights)?
Kowalski
Thats not H4s, H4s are just a normal twin filament halogen bulb.
Xenon HID headlights are the ones that blind you every time the car with them goes over the slightest bump. By law HID headlights have to be self leveling, they're going to be a lot of fun in the years to come when they get old and malfunction, it'll be rather like having somebody with 3x intensity full beams shining at you full time.
Stuart McB
john alexander
Oystercatcher
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stuart McB</i>
HID lamps seem a good idea but the cost of replacement is hugh. The whole lamp has to be replaced.
....and what happens when you take it to France, where IIRC, you are required to have a spare set of bulbs?
Alan
Alan
Forth
dan.2cv
HID's are expensive to specify on a new car ( I remember £1000 option on a new Focus) the bulbs are expected to last the car's lifetime and shouldn't wear out like normal halogen bulbs.
The HID bulbs from BMW were £135 each when I enquired about fitting them to my E30 at the time I thought you could just plug them in.
FrenchLeave
The new blue Xenon lights don't use a filament in a bulb; they rely on an arc between two tungsten terminals. As for Forth's diatribe about foglights, it's been a requirement in this country for at least the last 53 years (the time I've been driving) that any light with its centre less than two feet above road level may only be used in fog or falling snow. This is why a number of cars in the past had pop up headlights - to put the above the two foot mark. Why would he want to use fog lights in clear conditions anyway?
tomsheppard
