The aux drivebelt in my car has started squeaking when the car is idling and in 'D' (it's an auto) in neutral it's silent and makes no noise whilst driving (that I can hear anyway). Had a poke around this morning and the belt deflection is about 3cm. If i push harder I can feel it going further under spring pressure which I presume is normal for an automatic tensioner.
My question is this: Is it likely the tensioner is weak or on it's way out? I believe the belt was changed around 15-20,000 miles ago and should last a bit longer than that (it shows no signs of deterioration).
thanks guys
Dan
auxillary belt squeal
Richard Gallagher
oilyspanner
