306 alarm
b21playa
306 alarm
Unread post by b21playa »
thinking of getting another dturbo and it doesnt come with alarm
can i get one and make it activate when i use the remote central locking?
PowerLee
Unread post by PowerLee »
Hi
Theres loads of alarms out there that control the central locking with there own plips.
Or you can get a Peugeot upgrade kit ( Dont laugh! ) That will even work form you original remote key, Theres a couple of other companys that make these also.
If the car you end up with comes with a infra red plip, Get an alarm fitted that works with its own plip & junk the Peugeot IR plip.
You really need to speak to an independent car alarm fitter to see what would be best for your needs.
b21playa
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PowerLee</i>
Hi
im gonna be fitting myself as on a budget
id rather use the pug ir key as its all in one and saves having an extra fob
is there no way to wire it, so the alarm activates / deactivates via the pug plip?
PowerLee
There is a way of using the Pug IR plip.
Either pop down the Pug dealer & get hold of the Defender upgrade kit that uses the cars original plip.
Or try somethink like the AN700
http://www.microscanalarms.co.uk/system/index.htm
b21playa
any idea on price for the defender upgrade
also is it any good?
PowerLee
Ive no idea on the price of any of the Defender upgrade systems, Keep an eye out on Ebay because they show up on there from time to time.
I cant really comment if its any good or not.
b21playa
just found out that the toad a850 and a850T and sigma m32 do as well
but where can i get these cheap?
PowerLee
Ebay or a car alarm dealer may be able to help you out.
b21playa
cheers for help m8
will look around
PowerLee
When you get the car have a look & see if the wiring loom is already set up for the factory fit alarm, It might just be a trip down the scrapyard & plug a few bits in.
Peugeot started to only use one body loom design per car model around 94 / 95 to cut down costs, Theres loads of spare plugs on my 405 for things never fitted to a U.K. spec car.
b21playa
Peugeot started to only use one loom design per car model around 94 / 95 to cut down costs, Theres loads of spare plugs on my 405 for things never fitted to a U.K. spec car.
thing is that the pug alarms are crapand known for it
both my 306's had alarm problems
PowerLee
Just look at my siggy! lol
My Pug alarm used to go off when it felt like it, Even when locked in a garage at night.
Peugeot couldnt fix it, So I removed it & replaced it with something slightly better.
b21playa
yeah on my other 306, i just never armed the alarm
but on the next one i will do
trying to find the cheapest place for one
Linchpin
Unread post by Linchpin »
My alarm was going on constantly... so i disconnected one of the sensors in the pillar by the windscreen... nice and quiet now ... shhhh :-D
