Hello all,
My interior fan (or blower motor, depending where you're from) has become intermittant again ('96 TDLX with A/C). The ignition switch, being the obvious answer was replaced not long ago when the problem last surfaced so isn't likely to be the cause. Wiggling the key doesn't help.
So, what is the next most likely answer?? Assuming I don't find a bad contact when I take it apart, I'm think that after 129k of operation the brushes on the motor might be a bit tired. Failing this it could be the air-con version of a rheostat (sp?), mounted on the fan itself. Obviously I would prefer it to be the brushes!!! (=cheap fix) The problem might also have resulted from a leaking windscreen (which will move outwards when I push from the inside - is this normal????) soaking the fan assembly in a downpour!!
Anyone have any opinions/experience on this??
Cheers,
Another intermittant interior fan?
NiSk
Chris Peddie
Chris Peddie
