As an experiment, I removed the 2 plastic clips on otherwise working front and rear height correctors.
The results are the suspension will ONLY be fully up or fully down depending on which direction you LAST moved the internal height adjuster.
This simulates when the white plastic link fails when either end DISCONNECTS from it's ball socket.
I hope this clears up this all too familiar fault when the above symtoms appear.
(as with all tests they are open to debate, if anyone disagrees please say so)
Xantia suspension only goes fully up or down
No kidding?As an experiment, I removed the 2 plastic clips on otherwise working front and rear height correctors.
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
lolingram wrote:No kidding?As an experiment, I removed the 2 plastic clips on otherwise working front and rear height correctors.
That reply above was a long time coming, & if it were to be done on 03/02/2009 would have been four years approx after the original!
ACTIVA
I wasn't here 4 years ago 8) !That reply above was a long time coming, & if it were to be done on 03/02/2009 would have been four years Wink approx after the original!
Previously...
Previously...
